How do I wash the sails?
123
Columbia Yachts C22 Long Beach
I've heard of soaking them in the bath tub. Anyone got any recomendations of how to do it and what products to buy? I just painted the boat, now I gotta get my sails purty.
-Joel
Feb 10, 2004
4,253
Hunter 40.5 Warwick, RI
Rub-a-Dub-dub, I clean in a trough (sorry, very bad rhyme..)
I have cleaned in a hottub, stirring with an oar. Really low-tech, but works.
My present system consists of a 2x6 framework that is 16 feet by 4 feet. The framework is bolted together so that the bolt heads are on the outside, away from the sail. I line the framework with a large plastic sheet and fill with water. You need to find a flat surface in order to keep a reasonable water depth.
I pull the sail into the trough, one section at a time and brush with a soft bristle brush. Flip the sail and do the other side. I use a half cup of liquid dish soap. Wear water shoes so you can walk on the sail and in the trough.
Then I hoist the sail to the top of my garage, rinse with a hose and stretch it out to dry. I have also laid it on my lawn to dry. Both methods work fine. The lawn dry is easier.
590
PDQ 32 Deale, MD
But, watch out if you have oak trees!
I did this once and some acorns fell on it while drying. Nasty tannin stains. I think it depends on the lawn.
