Paul—
This is why I generally recommend that most bilges have a dual automatic pump setup. One pump is a small "maintenance" pump, which has a float switch as low in the bilge as possible. The second is a much larger dewatering pump, which has a float switch about an inch or two above the "maintenance" pump's float switch. The maintenance pump has a much smaller hose and the backwash from when the pump shuts down is much less, and generally prevents the short-cycling of the pump.
Ideally, you should also have two high capacity manual bilge pumps, one accessible from the cockpit and one accessible from inside the boat, preferably with both mounted near the companionway... but on a coastal cruising boat, this is usually overkill.
Well Stu I put everything back together today and did not reinstall the check valve:dance::dance::dance::dance:.
I put the bilge pump switch in auto position and the pump comes on and pumps the water out.
The bilge pump shuts off and the water comes back in and trips the float switch and the pump comes on and pumps the water out again and again and again.
This was so funny I stared laughing until tears came to my eyes.
I fixed the problem with a Rube Goldberg.....tossed in a ShamWow
When I came up on deck I was pleased to see I had provided the dock entertainment tonight for everyone......
paulj :troll:
