" im gonna float her in the launch area for 3 days before i leave, and stay onboard. I asked and they said i could leave her in and stay aboard."
This is an excellent idea! Keep a good flashlight handy, and do not run any noisey fans, heaters, A/C units, etc. Have the bilge covers either off, or ready for quick inspection. Be sure your bilge pumps are functional, and that they will pump water out. It may seem silly, but I keep reading stories about pumps bringing water into the boat. The thread has covered double stainless clamps, through hulls, packing glands, etc. and your surveyor should help set your mind at ease. Think about where water could come in your boat. Does your head/ holding system use salt water? What about the engine cooling system, is there a vented loop? Are the through hulls for depth transducer, or speed indicator checked and lubed?
OK, your boat partially sank, but I am guessing it will float just fine. What does your fuel look like? Do you have extra filters? Are you familiar with how to change them? 3-Years can be hard on diesel. Fuel polishing is a great thing, but if money is getting tight, just find the inspection cover and take a look. You can siphone the old fuel out if necessary, and clean the tank by hand. I recently crewed for a proffessional Captain bringing a boat from Puerto Vallarta, MX to San Diego, CA. The boat was a beautiful, and well maintained, Passport 47, but the filters looked foggy and showed some paticlate debree. We popped the inspection plates on the main tanks and they were clean with good tranparent fuel. We popped the cover off the day tank, and it looked like turtle soup! We siphoned the bad fuel out cleaned up the tank, added new fuel and changed all the filters. We had a great trip up the coast. Stopped in Cabo, and Turtle Bay. Truly great fun!
I can not tell you the number of stories I have heard, where boats (and lives) were lost because engines failed to run at critical times. My simple point here is your check list needs to include the regular maintenance items as well. Not just those involving hull integrity. How long since the salt water impeller was changed? Engine fluids like OIL and Coolant should be at least topped off, but hopefully changed after three years. Trans fluid look good, with no mulcification? Did an fluid make it into the exhust during the partial sinking (most marine mufflers have a drain). If it was out from three years ago, did you put it back? Remmember, we do this for FUN
Mark Wieber (www.Goliard.us.com)
