1
1984hunter27
Hi, I have a westerbeke 2 cyl 10hp in my 1984 Hunter 27. In neutral it will rev to 3000 rpms full throttle, under load going fwd it will only do 2400rpms. This doesn't seem right. any suggestions? thx!
You may be a little over-propped, but 2400 RPM on a two-banger under load, with 3k WOT, seems about right to me. What is your speed over the ground? Your expectations may be a little out.
I have the same boat (1984) and had the same problem a couple of years back. It was unseasonably warm and the boat sat unused for a few weeks because I was away.Hi, I have a westerbeke 2 cyl 10hp in my 1984 Hunter 27. In neutral it will rev to 3000 rpms full throttle, under load going fwd it will only do 2400rpms. This doesn't seem right. any suggestions? thx!
When I returned - same symptoms as you describe.
By that time it was near end of season so I waited till the boat was hauled - turned out that the marine growth on the prop had really flourished. It was cleaned and each year now Petit spray is applied and problem has never returned.
This is the 3rd season with the boat. I remember the RPMs going higher than they do now but I've had some problems with the engine since I bought it. I've had to swap out the injectors, clean the fuel tank, new alterator, new modern racor primary fuel fliter, install sea strainer, had a valve job done, among the other standard stuff (oil changes, fuel filters). I am a novice at this stuff but hoping to become fairly competent. It now cruises at 4.5 SOG when it used to go 5.25-5.5 SOG.Hi, I have a westerbeke 2 cyl 10hp in my 1984 Hunter 27. In neutral it will rev to 3000 rpms full throttle, under load going fwd it will only do 2400rpms. This doesn't seem right. any suggestions? thx!
OK, at http://www.westerbeke.com/productBrochures/w10_two.pdfI must respectfully disagree with those who said this sounds about right. While the engine may very well turn a few more RPM in neutral than in gear, a 600 RPM spread is far more than would be acceptable. Those who say that it should turn up it max rated RPM, in gear, are correct. Other wise there is something not right. I think most sailboats are not propped correctly. And they should be. Not sure what max RPM is on your engine, but should be somewhere around 3000. I can turn 3500, with a max rating of 3400, boat empty of water, little fuel, and no provisions on board. Loaded up ready for a trip, max is about 3250 to 3300, with clean prop and bottom. Doesn't take much bottom growth to knock a hundred RPM, or two hundred off that number.
When we bought it in the spring of 2006 we had it hauled and painted with 2 coats of bottom paint. Since we have had divers change zincs and inspect the bottom but have not had a diver down in a year. I called one today to set up a time to scrub the bottom and change zincs.What has been done to the bottom since the boat was first purchased? If nothing, then there is the probable cause.
I will check the micron size, it's an electric fuel pump. thanks so much guys for your help, this really makes everything easier.I hate to go here because this was just beat to death in another thread... You said you changed the fuel filter? What size is the filter.: 2? 10? 30? 2 might starve your engine unless you have an electric fuel pump- which does not seem likely, though possible.
Hi Dave, yes, same person. It's definitly slower, i have a diver coming next week to scrub the bottom and change the zincs. again, thanks so much fellow sailors for your help.Is ..84Hunter.. and Pat B. the same person?
Since you've been through a lot of the more complex (and expensive) engine maintenance items once already, focus on the easiest (least expensive) possible causes first... Bottom condition, throttle function, etc.. When you check throttle function, make sure you're using the cockpit throttle lever to move through the full range of travel, and not just measuring at the engine end when the problem could be at the throttle lever. Ten HP isn't a lot, check bottom and prop condition first.
I'm new to this as well, but you mention SOG as your basis for comparison. IF you are in the Puget Sound, are currents a factor in your SOG performance? RPM not withstanding... Puget Sound tides and currents can be significant, I would not rely on a GPS and SOG to evaluate my speed through the water.
Dave
One other thing to consider: is your Tach accurate? Might be an idea to get/borrow/rent a "hand tach" and confirm the tach is accurate. Things have to be REALLY wrong for an engine to not make max RPM in neutral. One other thing might be HP pump and/or governor...If your engine is rated for 3600 in neutral, and only turns 3000, then I would look at something other than the bottom.
