Making Battery Cables?
Bob S
Sep 27, 2007
1,815
Beneteau 393 New Bedford, MA
If I was to parallel (2) #4 wires could you use one 2/0 lug or is it better to use two # 4 lugs and piggy back them on the post?
Two
and better yet to get them off the battery posts onto a PDP (distribution post - like a Power Post) so only one wire hits the battery terminal.
Oct 22, 2008
3,502
- Telstar 28 Buzzards Bay
Definitely use two properly sized lugs. The crimp connection is far more likely to fail if you're putting two wires into a larger crimp terminal.
Jun 6, 2006
6,990
What is the application
Are you terminating the ground at the battery or what.
Stu is correct, use the correct size cable to take the circuit to a buss and then take power from there in all the various size wires.
Beneteau 323 Annapolis MD
If you're using "only" size 4 wire- what do they connect to at the other end, and are there any other wires on the battery post?. But, yes, individual lugs.
GuyT
May 8, 2007
406
Hunter 34 South Amboy, NJ
You would have to parallel 3 #4's to equal the 2/0 wire.
So your two wires would be way undersized for a 2/0 lug.
Go with the correct lug.
Bob S
Sep 27, 2007
1,815
Thanks, Looking back it's a dumb question. I was paralleling 2 existing 4AWG wires from the house bank to pst #1 of the distribution switch. It's only 6' so I decided to run a new 2AWG. I took Stu's advise and got a couple of Power Posts.
May 11, 2005
3,431
Seidelman S37 Slidell, La.
Cheap crimper
I can smell the smoke from mainesail all the way to New Orleans before I even write this. (Couldn't resist maine, and hope you don't take offense.) But I am one of the more frugal on this board, and you can read that as cheeeeeep, and actually kind of proud of it. For those who want to make up a good crimp connection on a battery cable, and don't want to spend the big bucks for a really good crimper, and don't like the results from a cheap crimper here is a solution. Split a nut with a hacksaw, that is somewhat smaller than the size of the lug. Put the split nut around the lug, and stick it in a vise. Tighten accordingly. This will make an excellent crimp connection, without the need for a high dollar tool, that will probably get lost before you ever need it again.
7,744
Alden 50 Sarasota, Florida
This one has my vote of the ingenious award. Good suggestion!
I've always taken the lazy approach and just gone to the local alternator guy which every town seems to have. They always have every conceivable form of crimper and are usually happy to make up the cables from their spare parts but I like your idea more.
You need a fuse close to your battery. Depending on circuit breaker draw expectations. 100 amps is a usual starting point, but certainly fused less than the capacity of the #2 wire. If you are just running to the switch, you wouldn't need the power post.
Bob S
Sep 27, 2007
1,815
Ron,
There is the parallel #2 from combining 2 batteries, another #2 to the switch, another #2 from the alternator going directly to the house along with 2 #18's from the battery monitor. God know what else will end up there.
11,772
Ron,
Bob,
If you know your lengths and stud sizes needed genuinedealz.com has about the best prices for marine battery cables/crimping/heat shrinking on the planet..
That's a hefty alternator cable. Do you really need two 18's since the batteries are in parallel- but I'll assume you mean one pos and one neg? As long as a parallel cable and switch were on one + battery post, and a parallel and alternator were on the + post of the other battery, I think you'd be okay w/o other posts. That sounds like a normal setup- like on my new Benny. You do take your starter and house load from the switch. Itermediate post add another possible loose and/or corrosion place. Any more than this and you'd want a post as Stu suggested. Did the directions say to run the monitor wires right off the battery?
