I was working on my fresh water system because it was scuzzy! The tanks had an odor so I was cleaning them out using the Peggy Hall method. I probably should have done this earlier in the year.
My system had a water filter before the pump (this was an add on thing). I noticed that my pump seemed to be working harder than it should and it was struggling. I couldn't figure out why and check every possible thing for a leak or something blocking the pressure.
Then it dawned on me. I haven't been able to find a replacement filter for this system so I haven't changed the filter in a few years. I pulled the filter out, put the system back together and PRESTO!
Do not confuse this filter with the strainer before the pump, this is an additional thing that the previous owner added.
So I got to thinking, how many times have you been working on something on the boat and forgot to check the most obvious thing?
