I would like to show a hitch that I have discovered and ask what you think.
First I am a humble student of seamanship, especially learning new and improved techniques for sailing and docking. Captain Jack Lang is a great teacher on single handed docking and sailing.
Scenario: You are by yourself at the fuel dock and boats are everywhere. Your bow is pointed into the wind. You know the technique to use fender and a line attached at the bow to walk the stern away from the dock until you can safely back away. The problem is that the loop around the pylon has to be let go, and the line will fall to the water. You will drag it until you can move to the front and retrieve it.
Imagine the hitch pictured. The blue pen is the pylon. The top line is the standing end attached to your bow cleat. The coiled end at the bottom is the bitter end that is lead astern to where you have it ready to be pulled. No tension is on the bitter end at this time. You successfully put the boat in forward and slowly move the stern away from the dock. When you are ready to release from the pylon you just pull the bitter end. The hitch will come apart and all of the line will be on the boat.
What do you think?
I have used this many times and I have found many uses. I once even walked a boat down a dock using a series of these and never had to leave the cockpit.
What do you think?
