I just installed the Coleman CL-3900 with CC-4000 charge controller on my boat. Upon activation the (3) 4D Batteries were at 12.4v. Within a couple of hours, in full sunlight, brought up the voltage to 13.7 volts nicely. I then disconnected from the system using a switch I installed, started the engine and continued to charge the bat. The voltage got to 14v, I then shut off the engine and switched on the solar panels again. There are LEDs on the individual solar panels that indicate voltage present, they were now blinking when they were on full before. Is that correct should they be blinking? If that is correct wouldn't that mean that to control the current flow to avoid over charging the batteries the output of the panels are being shunted to ground by the CC-4000? (in fact I disconnected and they went on solid again) I then turned on some nav/com equipment and brought the voltage down to 13 and they stopped blinking and were on full again. That would be a pretty bad design, or do I have a faulty controller? I think the controller is crap, but I just need it for bat. maintenance. I'm a little concerned that by sinking the current to ground in order to pulse the bat. it will be putting strain on the solar panels. Specifically the interface between the wire and the substrate. As an EEE I would not design a circuit like this, open it up to the bat. to pulse not shunt to ground. Anyway just wanted some other opin. I have send an email to the manufacture, it may just be bad. I'm also looking into the MPPT NC 25A-12, found one for $95. http://www.solarseller.com/flexcharge_wind_hydro_solar_charge_controllers.htmhttp://www.solarseller.com/flexcharge_wind_hydro_solar_charge_controllers.htm
