I would like to hook my head intake directly to the fresh water supply. I know some will say this is a waste of water, others will say to just hook up the tee to the sink drain - but for some a fresh water hook up would be best since there is minimal usage of the head (thus creating odors from the sea water) so water would not be wasted at any great rate, there is enough fresh water on the boat for the demand, and that the location of the tee - due to configuations would be above the water line causing the tee set-up to suck air at times when using the sea water.
Is there a confident check valve that can be used in this application for fresh water feed to the head? I'm sure there is a host of cruisers all ready doing this - are you using just valves or check valves or both?
