Electric polisher and buffer
paulj
Mar 16, 2007
1,361
Catalina 310 Anacortes,Wa
My 26 year old Porter Cable is broken and beyond reasonable repair.
I'm looking for recomendations for new electrical polisher-buffer for doing the gelcoat maintenance.
paulj :troll:
What month was the 1999 Atlantic City boat show?
11,772
Makita
The Makita 9227C is my favorite buffer for gelcoat. It will also go as slow as 600 RPM, which is very useful, and has a thumb dial speed wheel for speed adjustment.
RAD
Jun 3, 2004
2,330
Catalina 30 Bay Shore, N.Y.
After recommendations from MS, I bought the The Makita 9227C and it has become one of my favorite tools and my boat never looked so good after following directions
to the letter!
7,744
Alden 50 Sarasota, Florida
I'd suggest you also compare PC and Dewalt, both of which make comparable buffers with similar features. The only caution I'd add is to compare weights as you'll be holding it for prolonged periods. It's all about the pads more so than what turns them.
Tim R.
May 27, 2004
3,626
I also use the Makita and I can tell you that it is a better quality tool than the PC or Dewalt. We sell all three brands and the Makitas are preferred by our professional contractors. That says a lot about the quality.
11,772
Weight & speeds
Paul:
26 years? Why would you consider anything else?
Perhaps because Porter Cable no longer makes circular polishers.:confused:
Unfortunately their DA polishers, like the 7424, do not perform on gelcoat like a true circular machine does. One of the best electric DA's is made by Flex a German company and from what I have heard they do work ok on gelcoat but are quite expensive. I have not personally used a Flex DA on glecoat though so I won't make a judgment on performance. I have tried the PC 7424 DA on gelcoat and it basically just moved compound around.:doh:
Dewalt 849 = 8.25 Lbs. Min speed 1000 RPM
Makita 9227C = 6.6 Lbs. Min speed 600 RPM
600 RPM is a very useful speed for novices and it's hard to find a durable circular buffer at less weight than the Makita..
RichH
Feb 14, 2005
4,773
I think it was February and was held in the then new Visitors center.
Ditto on the Makita 9227C ... the slower speed is also superb for buffing varnish and acrylic/urethane boat 'brightwork' finishes, etc.
11,772
Rich that looks amazing! Have you had a chance to try Presta Chroma 1500 or their Ultra Cutting Creme? I think you'd really like it..
Jul 24, 2006
628
Legnos, Starwind, Regal Mystic 30 cutter, 22 trailer sailor, bow rider NEW PORT RICHEY, FL
whatever you do don't go for the cheap buffers. I did it and basically wasted $60. on almost useless junk. I have been useing an old chraftsman buffer for years and the shaft bearing went out on it. Being cash strapped i opted for the best Manufacturer sales advertisement online. It has a thumb dial for spead and looks similar to the Makita buffer but thats all. It did come with a spare set of brushes though? must be they go pretty quick. I tried it with a loop sanding pad and it has no power, unless you run it full out.
BobM
Jun 10, 2004
3,269
S2 9.2A Winthrop, MA
Ditto
Me too...bought a cheap buffer...got what I paid for...stalls out under pressure and essentially worthless.
paulj
Mar 16, 2007
1,361
Thanks everyone for all the information.
Wound up buying a Makita 9227C5x with buffer package on line for $208.
paulj :troll:
Sep 24, 2006
236
Sabre 36 Express Chattanooga, TN
Don said "it's all about the pads." What pads and pad holder do you recommend for the Makita 9227c?
Agaliha
Tim R.
May 27, 2004
3,626
The foam pads will work with the Makita out of the box. If you want to go a step higher with wool pads I would recommend Presta.
You can get the pads and compounds from Presta. http://www.prestaonlinestore.com/
The black pad is used with the cutting creme and the blue pad is used with the Chroma. You need to buy one adapter for the Makita. I just ordered their gel coat compound which is a little more agressive than the cutting creme and it uses a white wool pad. I will report back with photos after I give it a try.
Sep 20, 2006
2,955
I bought the Dewalt version only because it was handy and available when it was needed last year.
I did the topsides last weekend and my arms / elbows are still sore from holding the buffer vertical on the top of a stepladder, for a few hours. :cry:
Did a very nice job though. :D
Pat T
Feb 15, 2009
162
Catalina 36MKII Waukegan, IL
Approximate cost for the Makita? After 12 or so years I may have to break down and buy one. My boat gets bigger every spring. Also, I have a Sears buffer that I have never used but I think it is a higher RPM. Is there a way to reduce the speed electrically by adding some sort of in line rheostat?
Gail R
Apr 22, 2009
261
Pearson 34 Freeport, ME
Okay you guys, you inspired my other half to buy the Makita. We have a very happy camper at the end of a very productive weekend! Rita P doesn't look brand new, but she looks pretty decent for a 31-year-old!
Thanks for the recommendation.
