This thru hull is at the bow for the head discharge and it appears to be a 1-1/4" thru hull. The fitting is a RC Marine (marelon) fitting. What I first noticed to be a problem was the seal to one of the thru bolts had popped out when I scraped a little paint off. The material is spongy so I assume it was a 3M 4200 adhesive sealant. The photo shows the plug which is about 3/4" in diameter and 1/2" thick; however, I pried more material out of the hole as shown and the hole appears to be about 1 inch deep until the bolt head.
The inside photos show the RC Marine fitting with the washer and nuts holding the flange in place. I happened to twist on the bolts with my fingers and one of the screws just snapped right off ... I guess crevise corrosion took its toll.
I wasn't planning on a doing a complete swap-out of the thru hull fittings this spring but now I'm a little worried. Next off-season I had planned to strip off all the bottom paint and inspect all the thru hulls and replace them if I deemed necessary. I've had no leakage issues to date whatsoever.
Is it feasible to simply remove the 3 bolts and replace them without disturbing the seal to the thru hull and the flange? I would then fair the bolt holes with 3M Fast Cure 4000 UV as I have a fresh tube of it on hand.
