The original screws for the part in the picture below gave away, they were probably #12 screws. I drilled out the holes to 15/64" and used #14 screws.
The three screws shown in the picture seem to have taken to the job well. In the fourth hole, every time I put a screw in there, the threads get crushed and the screw does not take a bite.
Before I mess this up any further, I would appreciate any wisdom on getting this part on securely. What size holes should I drill for what size screw? The screw passes through the stainless steel unit shown in the picture, the extruded mast, and a bit of cast aluminum (mast cap). It would be a big pain to use a nut and bolt for this situation (because of the mast cap).
The piece in the picture is used as half a hinge, when stepping the mast, it faces pretty big loads.
