I have had both outboard powered sailboats and my boat now has the inboard diesel. The outboard power works okay until you get into bigger boats.
After having my inboard diesel, I wouldn't want to go back. Diesels run forever if they get proper maintenance, they charge batteries and heat the water heater, and they stay in the water when the boat is pitching due to waves. I will also say that if you have someone helping you out when you first start the diesel isn't that bad to do minimal work on.
Some boats run the risk of dunking the outboard in a large following sea.
Outboards work great for smaller coastal cruisers, but when you get a larger boat and you start going off shore, even a small distance, it isn't as good as the diesel.
btw....having an inboard diesel also keeps the resale value up much more than the outboard.
