Hello, What a beautiful day, 7o's with light breezes. But my boat is on the trailor, and I have a lot of leaks to fix. To that end, I would like to find out the best way to reinforce my chainplate. I have removed the chainplate and found that it is in a portion of the deck that is cored...and of course the core here is soft from leaks, so i took a drill with bent nail and removed the area of core around it and allowing it to dry with slow heat from a bulb.
I know that i want to use epoxy. but this repair is a little different than the typical because the chainplate hole is rectangular. I want a good fit to reduce chainplate movement when i am done. what is the best way to go about this. do i put a plug in the backside somehow (the liner is in the way) then fill with thickened epoxy and use a saw to cut out the hole. or is there somehing i can put in there, put in the epoxy, then remove that something when the epoxy cures, leaving a perfectly sized hole. any ideas?
I have read the epoxy works website, and while it is very usefull, i havn't seen this particular situation addressed
