How come you can buy a Y fitting for 3/4 inch plumbing. Seriously, they make T fittings but you can't find a Y fitting?
I would love to have a 3/4inch plumbing fitting that was a Y when I tie my sump pump into my sink drain. The reason for this is that I could direct the force downward towards the through hull fitting rather than using the T fitting that would give up and down pressure from the water entering the line from the sump pump.
Any thoughts?
Any thoughts?
