Anybody use an ANKAROLIA? Flat anchor line on a reel
luvitt
Oct 30, 2008
297
na na na
The boat im restoring came with a Ankarolina installed in the anchor locker. i didnt know what it was until just now. its flat anchor line on a reel. says it can handle 6600lbs and is the equivalent of a 1" line.
Anybody got any experience with one?
Thanks
Ariel
Feb 1, 2006
279
Pearson 36-2 Houston, TX / Rock Hall, MD
We have used an ANKAROLIA for years as we cruise the ICW and offshore. We have it on the stern anchor for the rode and, when we go offshore we disconnect it from the anchor and rig it around the mooring cleats as jack lines.
The only complaint we have is it will vibrate if there is a current running while using it as a rode and the vibration is transmitted to the boat. Because it is nylon it will stretch on deck when rigged as jack lines and it gets wet from rain or heavy due at night. Both are just minor nuisances. The best feature is it is out of the way when it is wound on the real and ready to drop the stearn anchor if the engine fails while waiting for a bridge.
This picture shows the line being used as jack lines as we are off shore and the real is half empty.
144
Hunter 36 Kristiansund N, Norway
It is used a lot in Norway, Sweeden and Denmark. Practical and strong.
2,288
C30 Event Horizon Port Aransas
optimism
That reel looks half full to me;)
What is a jack line? Something used to hold the bimini?
Oct 22, 2008
3,502
- Telstar 28 Buzzards Bay
Unfortunately, IIRC, the 6600 lbs. is the breaking strength of the webbing used in the Ankarolina. As such, it really isn't the strength of a 1" anchor line, which may have a working strength of 6600 lbs, but will have a breaking strength of considerably more, probably on the order of 30000 lbs. or so.
While it may suffice for a stern anchor line to stabilize the boat, you'd be crazy to use it as your primary rode, given that it is far more subject to chafe, and far weaker than the 1" rope rode that it puports to be able to take the place of.
Thanks
luvitt
Oct 30, 2008
297
na na na
thanks
thanks guys, I will use it for a stern anchor. ive read the same thing on other forums. at the moment it is mounted on the underside of the anchor locker door. just gotta move it.
thanks again.
