I haven't seen any mentions of a Southern Cross 35 or a Southern Cross 39. Both are supposed to be very good boats. Anyone have any experience with the type of haul that they are...A coored hull with some type of foam in between?
The more I look at them the more I favor a cutter rig. If it is blowing stink you can roll up the Jib and fly the yankee. The compromise that I see with a cutter is that it is probably a pain to tack because the jib has to go around the cutter stay. Some boats have a removable cutter stay, which is also nice, but I think that I would prefer a cutter right with both Jib and Yankee on a furler so that if the weather became nasty quick you don't have to go forward in rough seas.
Cabo Ricos seem nice too. A friend of mine has one and it is a beautiful boat. They are pretty inside and out, built strong, are heavy, and they have a good layout down below. The one issue that I see with my friend's boat is that it is a bit slow in light winds and in the Chesapeake Bay region they probably will be force to motor more than I do because I pass them regularly with my Catalina 30 pulling a hard dingy.
I also believe that if you are going to sea at all you are better off with an aft cockpit. My experience, which is rather brief, is that the center cockpits are higher so there is more motion with them and the ride isn't quite as nice as the aft cockpit. The center cockpit does give you a HUGE amount of room down below though.
V berth or Rear master suite? I use to really want an aft cabin in my boat. That was until I began spending most of my time at anchor and realized that I prefer to be in the front of the boat where you get the wind from the front hatch. Anyone else prefer this?
