Hello all....A question regarding electrical connections. I have currently 3 battery banks. One that is isolated from the other two battery banks that is located at my bow and is dedicated for bow thruster and windlass, one (bank 1) used for starter and one (bank 2) used for house. As the diagram below shows, from the alternator the power runs to the battery isolator sending charge to the bow battery, and then a wire runs to the starter and connects at main power to starter.
Questions
- Is this a typical set-up or should the alternator wire run from the isolator switch back to
the battery selector switch?
- With the current set-up, I am assuming the battery switch needs to be on both to
charge the house (#2) and starter (#1) banks?
- Also, any opinions...I only use the bow thruster / windlass when the engine is running,
and feel that the battery in the bow is a waste of unused power. I actually never use
my windlass and only use the bow thruster when pulling "into" my slip. I was thinking
about making that battery my dedicated starter battery as well as for the bow thruster /
windlass and attach it to the battery switch #1 and then add my current starter battery
to the house to increase capacity there.
Is this a logical set-up?
Thanks! Greg
Questions
Thanks! Greg
