As I've posted before, I'm about to change the bulkhead on my C36 MK II. This is the bulkhead that separates the head from the salon and is on the port side of the boat. This bulkhead is made up of two parts. There is a part that goes from the hull of the boat to about two feet in. Then there is the main bulkhead that goes from this point and is four feet wide. It is this part that has to be replaced.
If you look closely at the attached photo, you will see a thin, vertical strip of wood just to the left of the ss chain plate. This is where the joint between the two bulkheads is.
While I'm at it, I was thinking of strengthening this construction by through-bolting a stainless steel strap across the joint of these two pieces and then bolting an identical strap on the other side. I figure this would make the bulkhead in effect one continuous whole. Is there any reason anybody would know of that I shouldn't do this?
It wouldn't cost that much, would be pretty easy to do, and I figure would only make it stronger.
