Konstantin,
You have two threads of messages with same subject. Both threads are getting long.
Use short threads and the 'Ask an Owner' board. While your boat is bigger, the problems and solutions are general to all boats. If you keep the subject very specifie to each issue you may get help from others that until that specific question where not following your threads.
Let me start with the hull. Blisters are common on older O'Day sailboats. Some argue that some brand boats are free from blisters. Not true.
With the proper techniques blisters can be substantially repaired. However, anticipate that after the best repair in a couple of years you will get some more blisters. It is a constant upkeep issue, not a quality or safety issue.
Blister repair takes time and doing it correctly.
Sounds like you are making progress with rudder. Remember as to making boat repairs there are many good web sites, but they are in English.
This company has one of the best web sites for repairing with epoxy:
http://www.epoxyworks.com/
and go to:
http://www.epoxyworks.com/indexprojects.html
and look for instructions on 'Rudder Repair'.
Ed K
26
and go to:
Ed K
26
