The subject of drogues keeps coming up in the threads about heavy weather. Certainly, they are essential equipment for any boat going offshore for longer periods than weather forecasts can be relied upon.
I'm a big fan of the Series Drogue. Everything I know and can infer about waves and the behavior of vessels tells me that it is the cat's pajamas. I found the research and rational behind it quite compelling when read it. I may equip my boat with something else when the time comes however.
If drogues were one of those things we used constantly and switched models from time to time so we could compare, I have no doubt the series drogue would be Editor's choice every time. "Best" is sometimes just a small increment on top of "sufficient" however. Since many have gotten all the way around the world without needing a drogue I might choose something simpler and cheaper.
If you were to do an evaluation of drogues based on equal overall drag and total overall length, I think a graph of effectiveness, easy of control and depoyment, and other "goodness" factors would look something like what is shown below. Single drogues have worked as have milk crates and other stuff tied on to an anchor rode. Water moves back and forth in various parts of a wave so spreading the drag out so that the pull is an average of surface water motion behind the boat, instead of just an anchor at one point in it is, essential. However, I think there is probably a point of diminishing returns.
The Series Drogue would be way off to the right in the graph and clearly superior but, by how much? I might well opt for 6 - 8 small cone sea anchors that I could tie into an anchor rode with the line running through the holes in the cone ends. It would stow more compactly and probably be something I could make myself more cheaply.
Spreading 6 - 8 small cones out over the same distance ought to achieve fairly similar results. I would be very interested though in any actual drogue use accounts that might challenge this proposition.
