Which way
OK so the sails get pushed to leeward and the boat goes to leeward but the keel resists. That would make the LRF on the keel by the water a force directed to windward. Hence the moment or couple (of forces), sails to leeward and keel to windward. That makes the boat heel over to leeward.
That is the "drag it sideways through the water" version and did not account for the force that the keel produces by virtue of being drug forward through the water.
So now the keel is going forward and a little to leeward with the low pressure side would be to windward and the high pressure side to leeward. That would produce a LRF directed to windward.
I was assuming that we where actually trying to build (discuss) a keel that would provide some force to leeward, there by helping the ballast reduce heel. Making the boat lighter (less ballast required) and faster...... What you are describing is a keel that only produces forces that actually make the heeling greater. That would require a heavier (or deeper) keel to keep heel at reasonable levels. That is the way my keel works now and you are trying to increase the negative aspects of it????!!!
So, besides the trash collection feature, how is this a better sailboat keel?
