Not so ...
Heavy full keeled boat differ greatly from lightweight fin keelers.
Agree that perfect trim is important but to attain that with a 'heavy' requires a lot more.
A heavyweight full keeler will not accelerate as well as a fin keeler, a full keeler will be hard to turn into and out of a tack
'At speed' sailing requires flatter sails (watch your telltales)... Powering out of a tack after a fullkeeler has lost most of its momentum requires a 'LOW GEAR' shape/trim setting. In between being almost stopped and full speed requires gradually retriming while you watch the VMG and the speedo. You can easily 'get away' without powering up and down in dinghies, lightweight sportboats and finkeelers .... but you really have to 'shift the gears' to sail a narrow heavy full-keeler well.
Powering-up during a tack on a full keeler needs: opening the distance between the jibs leech and the main, dropping the main traveller a bit, hooking the battens to weather a wee bit, .... if possible - easing the main outhaul (if convenient) to get more draft into the main.
A full keel heavyweight does NOT like to tack. Tacking is for fin keelers, straight line sailing is for full keelers. If you force the wheel/tiller, the long keeled boat will almost come to a complete stop. Rather as you enter the tack, pull the mainsheet in with a lot of force .... to hook the aft ends of the battens 'up to weather' (like putting down the flaps on an airplane) this will increase heel which will increase weather helm .... and you tend to 'sail the boat through' the tack instead of entirely depending on the rudder. With a full keeler dont ever get into a tacking duel with a fin keeler. Use your momentum to 'bash' the waves out to the way when its boisterous - an advantage that fin keeler usually wont have.
First Gear for accelerating: Full draft, battens slightly hooked to weather, traveller slight dropped and jib leech allowed to fall a few inches further off the spreader tip. Tell tales flying perfectly (at this slow boat speed). Attempt to get as much increased draft into the TOP of the mainsail as possible .... but dont put in too much power or the fullkeeler will heel over too far and begin to 'skid off to leeward' - watch the rudder wake: it should remain straight with the boats centerline, not coming off at an angle
High Gear ... Second batten from the top --- ***aft end of the batten perfectly aligned with the boats centerline*** .... then do all shape and trim to keep the mainsail's tell tales perfectly flying and that second from the top batten 'parallel' so there's lots of 'umph' in the top of the mainsail.
Between low gear and high gear .... watch the tell tales, VMG and speedo then make slow trim/shape adjustments until at FULL speed. Do shape/trim corrections gradually (always TWO corrections, never 'just one').
Dont make any sail adjustment without consulting the speedo and VMG ... these two alone are the ultimate judge and jury.
