Replacing leaking plexiglass portlights
30
Seidelmann S299 New Brunswick Canada
Hi,
I am looking to replace the portlights on my S299 (Seidelmann). The current ones are screwed on from the outside and are quite cracked throughout. They are 3/8" plexiglass and I was looking for something a bit more robust. with a full aluminum seal and ones that open.
I have checked Lewmar for portlights, but I think the ones I require need to be a little convex to match the shape of the hull. Lewmar seems to only sell flat ones.
Does anyone have a brand to recommend to me to work with my boat?
Thanks,
Peter
Ross
Jun 15, 2004
14,693
Put a straight edge on the hull where you plan the changes and determine just how much curve you actually have.
Tim R.
May 27, 2004
3,626
Check the cabin top with a straight edge. Many look curved but do not curve enough to require shaped portlights.
I replaced all my portlights last off season with factory Bomars or custom Bomons. The longer portlights curve less than 1/8" from one end to the other on my cabin top.
Tricia
Jun 4, 2004
87
Freedom 30 Victoria, BC
re:portlights
If you can't find appropriate framed portlights, it is possible to replace the plexi: make the screwholes oversized so the plexi can expand and contract, use round headed screws and flat washers so that the pressure from the screws is on the surface of the plexi and not in the holes, and bed in Dow Corning 795, a construction grade silicone that's used for bedding windows in highrises. I replaced my portlights this way several years ago and there's no sign of cracking or leaking. If you do it this way, make sure ALL the old sealant is scraped and cleaned off so the new stuff has a good chance of adhering.
Tim R.
May 27, 2004
3,626
Ross
Jun 15, 2004
14,693
I paid about 200 each for Lewmar ports in the mid '90's.
