As promised down in the reefing thread, here are some thoughts on Lazy Jacks.
They are indespensable for lowering sails without having it turn into a Chinese fire drill. I couldn't sail without them single handed as I often am in a busy harbor. They make raising the sail too much of a pain to bother with however under the same conditions. Unless you have someone at the helm who knows how to steer back and forth at just the right moment or a spare hand to guide the leech, the batten ends will catch in them.
My solution is to stow them after the sail ties are on and re-deploy just before lowering. It only takes a minute and saves on chafe, slatting, and interferrence with reefing.
I'm a minimalist when it comes to the design of this gear as it doesn't take much to control the sail. I have a peeve with the "Lazy Jack Kits" I see. Smart salesman will sell you stuff you don't need and blocks in these rigs sure fall into the unnecessary expense category. Worse, they are wearing on your sails and making more slatting noise.
Here is how mine are rigged. Reefing hooks make this set up work especially well:
The standing parts that come down from the mast end in eyes with the smallest thimble I can get into the rope. I tried nylon but melted them rigging and unrigging too fast. Using a S.S. thimble a size too small for the rope works well and leaves plenty of rope bulk to protect the sail. Soft 1/4" dacron 3 strand is fine for a 32 foot boat. The lazy jacks end at eyestraps outboard, run through the standing parts coming down from the mast, and then to fairleads forward. I've been using thimbles lashed into a boom sail slide each side but will install something on the boom next year. This will be a pair of cheekblocks the smallest bullet blocks the line will go through secured with eyestraps.
There is a cleat on each side about 18" back from the gooseneck. To stow, I just grab the two legs, pull them forward and hook under the reefing hooks. Then pull the line tight and cleat. To deploy, unhook, pull tight, coil line and hang on cleats.
Having jacks that stow this way also makes putting the sail cover on a snap. I've seen covers with cut outs for the Lazy Jacks but the ones I've seen leave some sail exposed to UV and having a cover modified this way would cost more than it's worth.
