In Pensacola, we had a big blow the other night. I was out of town and not available to secure her in advance. The end result was that one of my dock lines broke and the boat rode up on top of a short piling and the it took a chunk out of my Hunter 26. As you can see from the photo, most of the damage was at the hull joint. There is also a straight 1-foot long crack just above the chewed out joint damage that goes all the way through. I also have some rubrail damage. I would appreciate some advice from some of you who have experience in fiberglass repair. I don't have fiberglass experience but am willing to try. My questions:
(1) Should I try this repair myself?
(2) How much of the damaged area should I cut back for the repair
(3) Should I treat the joint as a single piece (one repair surface) or separately repair the upper part and the lower part of the joint?
(3) How should I repair the crack above the gouged-out area?
(4) Is it possible to buy just a section of rubrail track that will match fairly well instead of a buying a complete rubrail and channel set for the whole boat?
Thanks in advance for your help! BrianW
