At the risk of looking like a moron, I have posted this for new sailors and seasoned ones too!!!
I averted a disaster recently... While sailing along in a calm wind I noticed the boom was dropping down... I Thought it was the topping lift that failed but ruled that out as the mainsail was up I looked up at the mast and saw that it was moving laterially... I immediately dispatched 2 crew to lower the main and jib as I had 1 man hug the main mast and keep it from crashing down... I assumed that the forestay failed and told the other person to use the jib sheet and wrap it around the bow cleat and draw it taught and cleat it off to the bow cleat when it was taught... I threw him leather work gloves and asked him to hold onto the forestay with forward tension also..
Then powered back to the dock, a 4 minute trip. The clevis pin for the forestay was not there...
How the retaining ring came out or failed is unknown and I probably will never know the cause... BUT IT SHOULD NEVER HAPPEN AGAIN!!!
The 3 friends with me said they didn't realize the danger we were in as I just handed out the orders to regain control in a calm manner... Inside I suppose I was flipped out as the possible outcomes raced through my mind...
I visably check the standing and running rigging and physically check the same every time before setting out. I will now check more closely that the the clevis pins and retaining rings are solid and intact.
The question is do you do this inspection? Please do!
