Hi All,
I wanted to share a method I have used as a temporary and sometimes permanent solution for the holes when deck hardware has been moved or removed.
Our boat has been upgraded to self tailing winches and we had not used the fixed cleats on the cockpit coaming since we bought the boat. The kids were banging heads on them so I figured it was time for them to go..
Here's what I did..
To make this an easy one person job I simply use my cordless impact wrench. This allows the nuts to be removed from one side only using no wrench or screw driver on deck.
Less Than 30 seconds later and notice the absolute lack of rust or moisture. These cleats were still bone dry after 29 years!!!! Why? Butyl tape as a bedding compound!!
To be continued limited to five images including smilies, Img and HTML IMG tags. We'll need to fix that....
Here's what I did..
