Looking for contact of a forum user - Bavaria 47 keel bolts issue
Nov 12, 2026
4
Bavaria 47 Cruiser Pärnu
Hello,
In 2011, a forum user called "gillesroy209" started a thread on suspected leaking keel bolts of his Bavaria 47. Here is the original thread: Keel bolts problem
To my understanding, gillesroy209 did not follow up with a solution - if any - to his problem. In fact, the three posts he made in this thread are his only posts in this forum.
As I'm having a similar issue with my 2001 Bavaria 47, I would be very grateful if anyone knows the person behind this user and could link us up via email or similar. I would like to ask him for advice. All I know based on his three posts and profile is that he is likely from Montreal and the boat set sail from Port Antonio Jamaica to Willemstad, Curacao when the issue struck. Thanks!
PS - I did send gillesroy209 a PM, however I doubt he will read it.
Your challenge may not be limited to Bavaria 47s. I just watched a YouTube video by James Evenson about his delivery experience on a Beneteau 47, where water entered the bilge in a similar way to what gillesroy209 reported.
Are you experiencing water leaking into the bilge?
Is it when the boat is sitting stagnant or under sail?
Do you have the boat out of the water?
The video above tries to identify the problem, which, in that case, is caused by the keel flexing and separating the keel joint and parts of the boat's internal structure.
Nov 12, 2026
4
Yeah, that'd be the worst case - a full grid delamination. However I think, by the looks of it, my 2001 Bavaria 47 Cruiser has at least part, if not all, of the grid glassed to the hull. My structural grid is made up of lateral frames, call them glass fiber boxes, that run 2/3 of the length of the boat. When looking into these boxes through limber holes, a bonded joint is seen. On the outside these boxes have been glassed to the hull. That is how it looks at least.
I'll make an effort and contact Bavaria about this. While the production yacht companies get flak for lots of things, Bavaria customer support has so far been quite helpful in looking up old drawings which predate company leadership changes. They could easily just flip me off (has happened to me with Lewmar, for example), but I've received exact technical drawings for my chainplates, tie rods etc from Bavaria. So I'd like to publicly thank them for this and encourage them to continue the practice.
Jun 1, 2004
8,357
Wow, 15 years ago. I also noticed mainsail was involved in that thread. In the past mainsail, who is a professional, was quite active here and highly respected for is knowledge, communication skills and willingness to share. So if you can't get hold of your guy, Mainesail's articles in this forums archives could help. Not sure how active he is any more, I know an illness slowed him down considerable but I have seen him make comments here and there so.... you never know.
Anyway, if your mystery Bavaria 47 is still around his contact info may still be in the database.
Go back to the thread and open the info box by hovering under his name and use the "send me a private message", It won't show the email, but it will redirect to it. That's the only ethical way to contact another forum member rather than asking a third party to relay information. The problem will be that since he no longer seems to be a participant he may have turned off any message notifications from this forum. Which means he was a one and done kinda guy, which would be unfortunate. There's always the chance that he's still lurks, like many folks do.. Good luck, I hope you guys hook up.
GillesRoy209 was last seen on SBO on Jan 21, 2011 after posting only 3 messages. Finding him here will be a very long shot.
MaineSail is still contributing here and on Facebook and other sailing forums, although he is not as prolific has he was before the stroke. Lately he has begun using videos as typing with one hand is challenging.
I would try using the "GillesRoy209" with the common email services like gmail, iCloud etc. Put Bravaria47 in the subject to help break through the spam.
dLj
Mar 23, 2017
5,258
As suggested above, contacting Mainesail may help..you can also post more detailed information here with photos and we can try to help. Is your boat located in Estonia or?
dj
Nov 12, 2026
4
dj
The boat is in Lanzarote, I sailed it here from Estonia this season and the issue has been with me ever since the beginning of the trip really. Want to get it checked before sailing across the pond.
Summary: saltwater found in bilge compartments during and after sailing into wind, especially when the boat is heeled over, boat is banging into the waves, waves sometimes wash over the boat. Hard to quantify the amount, 10 litres every 24/h? Could be less, could be more. Since the boat has a flat bottom, water can stay hidden in the various bilge areas and only slosh out when heel angle becomes sufficient.
Seems to be off the list:
  • The boat deck and hull seam has been glassed shut with three layers of heavy fiberglass, overriding the original factory sealant seam across the whole circumference of the boat. The boats previous owner had this done, as the sealant had worked loose and water was leaking in;
  • The teak toerail is a classic weak spot in my eyes, as the stanchion bases go through this double flexible joint (stanchion base - sealant - toerail - sealant - boat hull), however this has been worked over with sikaflex and butyl tape and after hosing the rail down, trying to flood the toerail, very little leakage is present. It explains the 2nd "floor" moist bunk matress in forward left cabin, but not a bucket of water every 24/h;
  • Forepeak stowage chamber bulkhead has been glassed over my me and made watertight. Even if its hatch leaked or even if the anchor locker leaked into this area, water would not be able to run past, it would pool in this stowage chamber. And it does not pool there;
  • There is no siphoning into the boat via bilge pumps. I have one pump disconnected (wooden plug rammed into through hull), the other bilge pump in the motor bay, added by me, has an anti siphon loop running up to the cockpit benches - as high as it can be. Furthermore, this bilge pump drains into the vertical transom;
  • Water is not entering via the rudder stock, as there is a flexible coupling with two large lip-seals around the stock and hull;
  • The two portholes I have have been removed and re-sealed with sikaflex (wish I'd done it with butyl tape instead, I'll pay the price later when it comes to swapping them out) this season;
I'll continue looking for siphoning options or loose seacocks. I did find a slightly leaky factory-original seacock which was not connected, it dripped ever so slightly. But a bucket every 24/h? Suspect ...
The sad option would be keel bolts. As I now know, my grid is glassed into the hull, about which I'm super happy, so there is no hidden widespread cracking happening that I cannot see. I can see all the keel reinforcing tabbing. There are some gelcoat cracks near the forward bolts and the aft bolts.
Most noticeably, I found one of the forward keel nut very loose when sitting in dry dock this spring. There was a rusty streak running from this bolt area outside the keel. I believe this was a bad install by the factory, as the nut washer was sitting on a considerable glass fiber reinforcement slope and the nut could work loose - the placement of the washer and nut was not flat.
I removed the lose nuts, inspected the stainless stud to the best of my ability, no crevice corrosion seen, cast a fiber reinforced epoxy leveling "puck" below this washer, re-tightened all keel bolts to 364 Nm (my keel studs have two nuts, the primary nut and a locking nut). I did not remove the lower nuts, simply torqued them over. I then removed some of the old flexible sealant from the hull-keel joint, not all of the joint. Water was definitely behind the flexible sealant. I wish I'd done the whole joint, but I wanted to leave port, as autumn was approaching.
So here is where I stand presently. Will likely haul the boat out next week or the week after to inspect the joint with some professionals here in Rubicon marina Lanzarote. I will before this inspect the joint myself under water at dockside to see if I can see hairline cracking, or any "smiles" in the paint and sealant around the keel-hull seam.
Meanwhile will also keep looking for siphoning options. I wish there would be a way to test any leak hypothesis before committing to keel rebedding. One thought I have is to glue (Sikaflex) sewage pipe couplings over all keel bolts, leaving their tops open. This way I can isolate all keel bolts and see if any water is actually coming via this route or not. But, again, sitting dockside, the bolts and threads remain bone dry (after pumping out the keels and drying them with a rag).
Here is a thought. When in the water, can you seal the area of concern with a tarp, then pump air into the space with a leaf blower. Slip into the water and look for bubbles. Might also work while out of the water with soapy water along any suspicious areas of keel/hull joint. The leaf blower pressurization has worked showing leaking ports.
Likes: LLoyd B
Could you put some paper towels or tissue paper around the bolts, then impact that every couple hours to see whether they’re leaking? That could give an idea whether water is going toward the bolts or away from them.
This is utter nonsense. Why? Because boats are not sealed pressure vessels. They do not blow up like balloons. They are definitely NOT airtight. Boats need ventilation, right? My boat has two dorade vents. Even if I closed them, they are designed to shed water ingress, not to seal off air. My top hatchboard has air slots in it, and they way they slot into the cabintop is definitely not airtight. My cockpit lockers do not have seals on them. My cockpit gauige panel sheds water but is not airtight. See the pattern? Tarps are not airtight either...
I’d agree with you, but @Crazy Dave Condon used to recommend a similar trick, for example at Hull/deck Leaks. I’m guessing it works better on small boats with less ventilation points and areas that need taping over though.
Nov 12, 2026
4
What do you mean by "impact that"? T'was a type and you meant inspect?
The present plan is to glue 80 mm sewage couplers around each bolt and go sailing. Also inspect the keel hull joint underwater before leaving dock for any obvious gapping.
