2008 H36. 5 Gallon Force 10/Kuuma 40500. Suddenly after working fine for 2 years, of course when I need to empty and winterize, the hot water no longer will flow from any of the 4 outlets on board. Cold side works perfectly well.
Main water pressure pump filtert is clean. The tank has a Watts MMV-V1 mixing valve to avoid scalding. i understand how all the supply lines are laid out at the front of the tank. I see no evidence of any type of filter or screen in the hot water supply side. Two questions for all the group. 1 - where would you look for a clog? 2 - how does one remove the mixing valve?
