Hello all, now that my inaugural season is done and Applause is on the hard, I’m planning the preseason work for 2027. Some of the items I’m seeing and would like some feedback on are:
A. Keel crack, it didn’t show on the survey and not in the place you’d expect, as we assume a crack on the keel comes from an impact and is at the top of the keel by the hull. This isn’t that. As seen in the picture, on the top of the angled edge of the shoal keel, there is a crack and some separation. What would you suggest?
B. Gauge goofiness. My fuel gauge has shown full all season, though it moves when under way. I was able to add 5 gallons during winterizing so I know it’s lying. Is this just a wire issue or is this a full replacement of the sensor? Next is the rpm gauge, it will read at 3500 when I push it as hard as I dare, but will then go down after a few minutes even if I don’t adjust the throttle. The engine speed sounds the same as well. The sensor is at the back of the engine so I suspect I need to inspect and clean it, anything else I should look for? Bonus question, what speed over ground should I expect at 3500 rpm and no headwind? If there is significant headwind, does the 310 struggle going upwind under power?
C. Cockpit lighting, only the rpm gauge lights up, not the compass, not the side panel with fuel gauge, not the floor light. Assuming I need a bunch of tiny bulbs, does anyone have a list of sizes?
That’s all for now.
That’s all for now.
creek without a paddle. And in our lonely, freezing northern waters not a good idea. Mind you, having said that, I do have a wooden backup measuring dowel which I use to check the fuel level every 4-5 or longer years.
