Maybe an annual hit with clear UV spray paint would help?
I am really tempted to get into this. But (a) I have a large shop with welding and machining capabilities and (b) I''m low on things I need to make. The other thing I find intriguing is the process of deciding the best way to make a thing. It used to be a fundamental part of the design process, and even with 3D printing, it still is.
post 1. Could have been made from scrap with a bandsaw, drill press, and sander in a few minutes. Too easy.
post 2. Interesting. The original was cast. A replacement would have been either cut, drilled, and bent from 1/4-inch aluminum, or possibly TIG welded from aluminum or stainless. Not difficult or time consuming. Alternatively, something could just be sourced. Not a common 3D machine, either.
post 3. Didn't come up for me.
Post 4. A few minutes with an end mill and a milling table (milling machine or drill press). Easy.
Post 5. Neat. Obviously, you could source that. I actually use bicycle water bottle holders, since we don't use cups much. If I wanted something cool and custom, I'd probably TIG something from some rod and tubing. Clamps are actually pretty fast to fabricate. I can't think of a simple way to add a name.
post 6. I fabricated a similar holder for a tablet on my last boat. Some bending, welding, and machining. An after-dinner project, similar complexity. I made a bird-blocker from 11 ga aluminum using a bending brake; looked factory made. I like the door latch, a good 3D project, but I'm not sure I like it as well as the simple hook/grommet my last boat came with; more secure in rough weather.
Post 18 could be cut from scrap in minutes.
Post 19 I could cut from GRP angle scrap.
The ones that puzzle me have concerns about UV resistance or strength. For example, a pulley is MADE to be turned. With a mandrel on a lathe or drill press with a lathe attachment, a smoother, more precise version can be turned in minutes from the correct material.
Every tool has a limited number of tricks. The old-school result was shop full of tools and a skill set for each. Lots of space and $$, which is a downside for the hobbyist. I have used 3D a few times at work, but only for odd prototypes of things that were going to be made from plastic.
I wonder if the old saw applies? "If all you have is a hammer, everything looks like a nail." Some of the projects on this thread are very cool and point in a new direction. Some, on the other hand, are clearly not nails. The trick has always been to design a part with both materials and fabrication methods in mind. A solution should not be forced by what is at hand.
But I'm going to keep following these threads. Someday I will find some "maker" interest that cannot otherwise be satisfied.
(The factory knob, broken down by foot traffic and UV after 30 years. A 3D-printed replacement would not be as strong or UV-resistant as the original. The turned replacements are several times stronger and will last even longer. The bearing surfaces are smooth. Once the jigs were set up, these literally took less than 2 minutes each, all steps included. They're a bit dirty in the photo, since I dropped them in a bucket. On the boat, cleaned up, they look better than factory. Machines are easy to set up for duplication. Of course, I could have printed them. That would have taken days. I could also have sourced them, which from a point of view, would be smarter. Maybe--a large number of the correct knob was ~ $250, and my cost was only time.)
