Some wiring tips
I couldn’t find an electric system specific forum so I thought I’d post this here. Found a very good video for the DIY electric systems sailor and wanted to share.
Likes: Allan12210
Sorry Rob, I wouldn't use any of those tricks on my boat or in my house. On the boat I'll stick with properly crimped connections using heat shrink connectors or good quality ferrules.
dLj
Mar 23, 2017
5,233
I wouldn't discard it all. If you are offshore and have to make a fix but don't have the correct bits, some of those tricks might come in handy. The solid core tricks wouldn't apply, I do not have any solid core on my boat.
To your point, doing a proper installation, yeah, do to right. But as a stop gap measure to get your boat home, there are some handy ideas in there.
dj
:cool:
What struck me is that if in a jam off-shore, how many of us have that much spare wire on the end of a failed connection, to strip and splice with?
Probably not many, but I do. I also carry crimpers, wire stripper, and a wide assortment of terminals. Most of which came in handy when anchored out in Hawk Channel in the Keys at night with a disabled engine and a main battery switch that just fell apart, leaving us in the dark with no lights, radio, or anything else. With some wire and fittings the main switch was bypassed and basic essential electrical functions were restored.
On each of my boats, I keep an old Army-surplus ammo box packed with wire, crimpers, connectors, and a small multimeter with spare batteries. Ironically, for a box full of “boat repair” supplies, it gets used more often running down a problem with the trailer lights.
Sep 30, 2008
104
Hunter 37.5 37.5 Norfolk
I believe those are all good techniques for attaching terminals to wire. They appear to be strong and solid. I do agree using ABYC standards is the best practice. However, I do not discount other methods because they are not the ones I prefer.
dLj
Mar 23, 2017
5,233
I think any of us that head offshore or at least fairly long ocean legs will carry spares.
Dave's list above is very similar to mine. I'll add - which he probably overlooked, I'm sure he cares one - is a very good multimeter. Mine also has an incorporated AC/DC amp meter. Really handy for diagnosing charging systems.
But it's near impossible to carry every conceivable wire size and connection possibility. I also carry two soldering irons, one for small electronic connections and one for larger wire soldering. Basically, I can rube goldberg together just about any conceivable electrical issue that may happen if I don't have the proper bits and pieces.
dj
