Aspiring Hunter owner - what to look for pre-survey
Oct 11, 2026
1
Capri 22 Lake Pleasant
Good afternoon all, I am looking to buy my first boat, I am a relatively experienced sailor, but have never bought, owned, or maintained a boat of any kind.
As I look about the market (San Diego, Southern CA area) it appears to me that a Hunter 340 or 376 best fits my requirements: daysailor, overnight to1 week stayaboard, and coastal sailing with periodic sailing to Catalina.
My question to the community is: If I focus on a hunter (340 or 376) what are the problem areas to check and clear before paying for a survey?
I won't buy without a survey, but I would prefer to pay only once and have a high confidence going into the survey that all will be acceptable.
I assume that the key points include:
  1. Look for soft spots on deck and anywhere else accessable
  2. Identify susp[ect cracking, softspots, rust where the chainplates enter the deck
  3. Look for wet bilge, rust in the water, rusty keel bolts
  4. Prioritize recent (documented) standing rigging
  5. Prioritize good records with verified work done on major systems
  6. ???
What am I missing? Where do Hunters tend to fail? The year range of the boats I see is in the mid-late 1990's.
Pricing seems consistent - ~'95 340 for $39k, ~'95 376 for $59k. Are these asking prices a reasonable starting point?
Thanks in advanvce for any advice.
Best,
Mike
PEBI
Sep 30, 2026
45
Homebuilt 35 muck
I'll share some of my advice when purchasing a boat. Or anything at all.
Like Don said the usual search on any forums for reviews. That's a good starting point.
But if you really want to get a better indepth review and enjoy your purchase. I'd advise searching for say e.g. (e.g. = example). Hunter 340 problems, Hunter 376 problems). If the model your researching has a lot of problems it doesn't take much to see what the most "common" problems are. Repairs can accumilate and get costly right?
LOL.
Ha ha.
Before I did research like this I bought based off of reputation of reviewer and magazine/website. Then found something I did not like after purchase and found a lot of customers all experienced a similiar problem as mine.
For e.g: The furler is mentioned in page results 4 times.
You're maybe overlooking the engine. Re-powering is expensive. Yeah, an engine on a sailboat is a governing factor. Go figure.
Likes: PEBI
Jan 4, 2006
7,816
When I had my 20 year insurance survey done, the surveyor told me that most surveyors don't do engine checks as it's too specialized and out of their area of expertise. You may find the same thing in your neighbourhood.
It may be worth your while to bring in a "licensed" mechanic (not a grease monkey) and get his thoughts on yours.
Learing how to maintain a diesel would be a huge investment now before you get the boat as they require endless fiddling (oil changes, Xmission fluid changes, new V-belts, battery replacement) which are extretely simple once you've seen how but will run about $150.00+/hr for a mechanic.
If you want the new boat to last for a good number of years, maintenance will be an ongoing occupation. Otherwise, forget the maintenance until you get hit with the really BIG bills.
Likes: PEBI
