The neat thing about salted varnish is that it is a ONE-coat process. The practice has a long tradition; I didn't invent it. A savvy old guy suggested it to me ~ 15 years ago, and I have used it many times, paint and varnish.
Isskrä, the walnut of which he speaks is crushed walnut shells. It is sometimes used as an abrasive to spray at pressure against a hull to remove the paint.
In this case a sprinkling is spread over wet varnish. When dry several more coats of varnish are add to seal the material and the base wood.
It is not considered a good wood species for exterior marine environments, but does hold up well on interior boat wood work.Does walnut hold up well inside a boat?
My preferred woods for exterior boat work are iroko, teak, red grandis, sapele, mahogany (hard to find good pieces though today), white oak, black locust, southern yellow pine, Oregon pine. There are others but it can depend on where and what they are being used for. For example lignum vitae is an amazing wood for the right application.I just purchased some mahogany from Menards. I read it will last 40 + years on the exterior if coated .....and if not coated, up to twenty ish. I built my own set of 7 foot long hand rails. I learned how to use a router. But I have no idea how to use the router on the ends where I go against the grain. So, I just used my random orbit sander on the ends. Any tips or info would be greatly appreciated
Isskrä
Welcome to the forums. If they will put up with some of my crazy questions, your good to go.I did know about walnut, bead and sand blasting. I've sand blasted before. And I'd be washing fine sand out of my ears for days.
But walnuts as a no skid is news to me. When I was little, they would add silica sand to paint to give it a non skid affect.
I'm glad I joined. I'm learning a lot. I wonder what else they might use these days to add to varnish, or paint for a non skid affect?
I should introduce myself the the group. I need to explain I'm autistic ( high spectrum ) before people get angry at me. I don't understand how it happens. But, in the past, I would post too often, or my humor would be a bit too much for some etc. If people know I'm autistic they might have more room for me. I've had a really tough past. I'm here because I thought it would be a way to make some friends in the areas of my interests. I know that it's unusual for a woman to have skills ( fabrication and construction, electrical etc ) I tried to reach out to a local yacht club. But those men were not the most accepting of autism and female solo sailors. Here is a floor project I'm working on tonight. I'm replacing the sole under the head. I'm using treated wood for the backer, and mdo board for the floor and home made mahogany shims
In response to your last edited comment. I cant find it. but i remember there was a result from a survey, or insurance compaany, cant remember which, floating around on one of the sailing forums a couple of years ago. If i remember correctly, the #1 injury/accident on boats was falling down the companionway.EDIT: I do not have links right now, but recall from OSHA or other organizations that have studied stairwells, that the way feet work, it might seem you slipped on the edge of the stair, but if the stair itself was grippy - you never would have made it that far to report that experience.
dj
Well gosh. Haha. That just gave me an excuse to be as odd as I can be. TeasingWelcome to the forums. If they will put up with some of my crazy questions, your good to go.
P.s. Bad Orca. I've never met a good orca. So I have no way to compareWell gosh. Haha. That just gave me an excuse to be as odd as I can be. Teasing
For me, it's slipping on the deck and off into the water. I need to put my netting back up.In response to your last edited comment. I cant find it. but i remember there was a result from a survey, or insurance compaany, cant remember which, floating around on one of the sailing forums a couple of years ago. If i remember correctly, the #1 injury/accident on boats was falling down the companionway.
lol...me either. Actually i have never met an Orca. Hopefully one of these days then i can report back.P.s. Bad Orca. I've never met a good orca. So I have no way to compare![]()
