Every sail boat needs a musical instrument
Talent comes from a youth well spent.
Is the copper then covered in a surface or just etched.
I love guitar music. Especially that of Spain and Argentina. Tango and the artistry of Segovia. I recently discovered Marcin Patrzałek. He has remarkable percussion skills.
But the guitar sitting there, I had a flashback moment to the stairway in the John Belushi movie Animal House.
Phil
Feb 11, 2017
354
Morris Annie Haleiwa, HI
Here's the process:
1. Use original pick guard to make a template out of plastic, plexiglass or similar
2. Use the template to cut out the shape using a router
3. Use the original pick guard to drill the mounting holes in the copper pick guard
4. Sand the copper with 220 grit then clean with acetone - always wear gloves when sanding and cleaning to avoid getting skin oils on the copper
5. Place the copper on some small wood blocks inside a large enough tupperware container
6. Press whatever you want to use for a semi masking material - I used hibiscus leaves. My brother used onion slices
7. Put ~1 tbsp of salt and ~4 ounces of ammonia in a spray bottle that can spray a fine mist. Mix by shaking.
8. Spray a fine mist of ammonia / salt on the copper. Try to avoid pooling - you can dab the pools gently with paper towel to remove them
9. Install the tupperware cover and let it sit for ~6 hours
10. Remove the copper pick guard and let it dry in air for ~6 hours
11. Gently rinse in a bath of warm water
12. Let the pick guard fully air dry
13. Spray 4 to 6 coats of clear, lacquer spray paint or brush with clear nail polish. I used Rust-Oleum clear lacquer spray finish and did 5 coats.
colemj
Jul 13, 2004
1,148
Love that pick guard - the colors and shades really complement the wood body.
Why not take it aboard? Sometimes it is cathartic to bang out some Sex Pistols or Ramones. Makes practicing finger work easier too. Of course, leave your Marshall stack at home - get one of those earphone plug things. They have remarkable sound shaping for just about any type of music you want.
I've got my Strat and two acoustics (Ovation and Woodsong) on board.
Phil
Feb 11, 2017
354
Yeah...I've thought about taking my Tele and my Grosh EJ to my boat with an earphone or bluetooth adapter, but my boats a bit smaller than yours.
Here's a pick guard my brother did for his garage sale LP Junior. He put onion pieces on the copper, wrapped it tight in a micro fiber cloth, dripped a few ounces of ammonia onto the cloth, then stuck it in a large tupper ware for ~5 hours.
RussC
Sep 11, 2015
1,735
Merit 22- Oregon lakes
I'm hesitant to take a guitar onboard because of the moisture but I often take my harmonica and sometimes on an extended trip I'll take one of my own native american style flutes, which I keep well protected in the cabin when not playing.
colemj
Jul 13, 2004
1,148
Man, both yours and his highly complement the specific guitars they are on, and neither would look good on the other guitar. The busyness of the LP guard would clash with the simple long grain of the telecaster, and the large pattern of the telecaster guard would look like someone stuck stickers on the LP.
That is great work. It is something I don't have the creativity to understand up front. I'd have to do many random trial and errors until this blind squirrel found the nut.
Mark
Likes: Phil
colemj
Jul 13, 2004
1,148
It is common for people to think this, but moisture is no problem for a guitar. It is dry conditions that really do them bad.
If you are concerned, there are inexpensive bags that you put in the case and they suck up moisture when it is humid, and give back moisture when it is dry. They work surprisingly well.
Mark
