I haven't taken one out yet, but I stood in one tied up. I was satisfied with its stability, though the setting was calm.
I had ordered one, but I thought it was getting discontinued, so I gave up hope on ever getting it. Low and behold, I revisited the page and found out it DID restock after all, and my order is being fulfilled as we speak. I will return here to give full thoughts after I finally receive it
I don't know the West Marine Classic Dinghy. I've never seen one directly. I was looking at the images on West Marine and note a couple things:
1) It doesn't seem to have a sailing option.
2) It looks like there is only one set of oar locks for the middle seat.
I have a Trinka 8' sailing dinghy. So it's smaller than the West Marine Classic Dinghy. That could have repercussions on my comments. It also looks like the Trinka is probably less stable than the West Marine Classic Dinghy. I've gotten used to that aspect.
I like to being able to sail. I don't have a motor for my dinghy although I've considered getting one but as it rows so well, the "need" is just not there...
If you don't care about sailing your dinghy, then the lack of a sailing option doesn't matter. I personally quite like that option.
I really like how my dinghy rows. My Trinka has two sets of oar locks so that it can be rowed from either the middle or forward bench. I've found that very useful depending upon how many people and how much equipment I may be carrying. I'm able to balance the boat much more efficiently having the option of the two different oar lock positions. I've often rowed from the front bench with someone sitting in the aft bench.
The West Marine Classic Dinghy says it handles only 3 people. That's probably some sort of safety thing. I've had 4 people in my Trinka and it's smaller that the West Marine Classic Dinghy. Now, I wouldn't say 4 people is a good idea all the time, but I've made it work. 3 people in my Trinka is no problem at all so I'm a bit surprised that the West Marine Classic Dinghy states 3 people max. It's larger than the Trinka 8 by quite a bit. Both state 3 people max in their original documents.
The West Marine Classic Dinghy looks like quite a nice hard dinghy. If you are going to row a lot, you may want to think about installing a second set of oar locks for the forward bench seat depending upon your usage. Adding in a sailing option would be very difficult. That dinghy looks like it is aimed at primarily being driven under motor.
dj
