My draft
Eli55
Sep 4, 2026
3
Hunter 34 Chesapeake
Hello i purchased a 1986 hunter 34. Its in the water I bought it through an auction. Is there anyway of known the draft without a haulout, or going in the water its a 1986 34 . It was # 956 of that year built and completed in November of 1985
dLj
Mar 23, 2017
5,255
According to sailboat data, your boat should have just under 6' of draft.
dj
Eli55
Sep 4, 2026
3
dj
I appreciate it. Yeah I know there had one under 6 feet and also on 4 feet and a quarter
The 4 1/4 is probably a shoal draft version- could even be a wing keel. Although SBD.com doesn't show a shoal draft version of the 34 Many models of sailboat are/were available with a choice of keels. Sailers in skinny water appreciate being able to use more shallow anchorages and having access to more marinas. So the question remains which you have. If in doubt use it as if it's 6 feet until you know differently.
Do you remember where the 4 1/4 number came from?
Eli55
Sep 4, 2026
3
Thank you gor the response. I had read online that it was an optionally order. It will need a haulout so I guess I'll know then amd treat it as a deeper draft until then as you said before ill know for certain.
Jun 21, 2004
3,225
Beneteau 343 Slidell, LA
I had a 1988 33.5; it was somewhat similar to the earlier 34 With respect to the hull. Mine had the shoal draft, cast iron, wing keel (4.25–4.5’ draft).
Likes: Eli55
Are you in the Chesapeake? If so, I assume you've either hired, or are planning to hire, a diver to keep the bottom clean. If that's the case, just ask the diver to identify which keel you have, then buy them a beer (or lunch) for the favor. :beer: That will be a lot cheaper than paying for a haul-out and you might make a friend who will keep an extra eye on the condition of your bottom.:cool:
Likes: Timm R Oday25
dLj
Mar 23, 2017
5,255
If you would like to hire a diver, I know one that does very good work and reasonable prices. Just send me a PM and I'll share info.
dj
Jun 27, 2004
117
Hunter 240 Seneca SC
I used to own a 1986 Hunter 34. There are 2 keels. The fin keel draws 5'7" and the shoal draft keel draws 4"4". The shoal draft is a Scheel keel.
The Scheel Keel is interesting. The Tartan 33 has one and it serves that boat quite well.
higgs
Aug 24, 2005
3,738
Nassau 34 Olcott, NY
Get a 30 ft line and put a weight in the middle. Using two people on either side bring the line to where the keel attaches to the boat and pull up the line until it hits the bottom of the keel. Subract freeboard and you should be able to know your draft.
Likes: JoeWhite
The boat is on the Chesapeake. Find a nice soft sand bar or mud flat and gently motor up to it. When it touches bottom use an extended boat hook to measure the water depth. Then back off the bar and go sailing.
From what I've read, the 34 is a bit tender with weather helm. It looks like the '86 is the first year Hunter addressed some of those criticisms with added ballast. I can't say which version you have, but the deep draft seems the most common. If you haven't hauled her out yet, do so. One of the most criticized problems with the 34 is corrosion of the encapsulated iron keel. You'll want to address the "Hunter smile" as soon as you can, and stop and water intrusion that might reach the iron keel.
Congratulations on your purchase. The 34 sounds like a fast boat.
-Will
