Our install of a P79 transducer faced several problems. First the kit enables you to adjust the device for up to 22 degree in a single direction. Our hull had tilted both fore and aft, and port to starboard. To compensate we used JB weld marine to build a small circle of compound.
First we drew the outline of the tank onto the hull. Then mixed the JB weld and placed it on the hull with a higher wall where needed to create a somewhat level base. The JB weld is like clay and allows significant adjustments as it slowly hardened. We placed wax paper on the top and then used a flat square to level the top. It took two applications to create the level base.
Then (a little messy) put the transducer into the tank and used a level to level it both fore and aft, and port to starboard
