Replacing Spinlock lever 3/8 rope Clutch
Jun 5, 2018
55
Beneteau 35S5 Buffalo, NY
I'm looking to replace my rope clutches and was wondering if anyone has a recomendation so i can use the existing holes.
Sep 24, 2018
4,613
Catalina 30 MKIII Chicago
I'm not sure what model you have but Spinlok does publish documentation regarding the hole placement. It may be referred to as a drill template, mounting template, or installation manual
Apr 8, 2010
2,243
Since it's time to over-drill, epoxy fill, and redrill all the holes, the new clutches can have slightly different holes by 3/8 or so and the new clutch base will cover it all.
When our OEM clutches were wearing out, I replaced them with the heavy duty D2 models from Lewmar. They work very well and hold our very-low-stretch (T-900) 5/16 halyards.
You might want to consider this upgrade...
Jun 21, 2004
3,159
Beneteau 343 Slidell, LA
They make kits to rebuild those, new handles too.
Terrific idea! Replacement kits are much more economical than replacing the entire clutch & also negates the need of filling holes & re-drilling. You Tube videos show that repair is fairly simple. I will definitely opt to rebuild vs replace.
Jan 7, 2014
462
Beneteau 45F5 51551 Port Jefferson
You will need to drive the pins out with a punch - just make sure to lube them up with liquid wrench beforehand. I did about 4 of them and I had one where the stainless and aluminum had seized, the others came out easy.
Likes: BigEasy
Jun 5, 2018
55
Thanks for the info.
