Tank gauges
Jan 4, 2006
7,676
WHY ?
What make are your present gauges ? Are you having problems with them ? If no problems, wait until they fail. I've been waiting 28 years and the only failure to date on a new 1998 boat is the holding tank which failed in the first month.
The only advantage of swapping out your sensors is that you may be able to see all of your tank read outs on one panel.
So long as the tank sensor hasn't failed there is no reason to upgrade the sensor, except perhaps to put the sensor information on the NMEA 2000 network. In which case it is not necessary to replace the sensor, a device like this one from Navico (Simrad/Lowrance/B&G). When I added tank sensors to the water tanks I used it and it works well.
Although pricey, the best tank sensor for a holding tank is the Gobius C. The big problem with float style sensors on holding tanks is the stuff in the tank which clogs the float. The Gobius C uses a micro-radar to sense tank levels even through the tank wall. Cool device that works well.
Jun 17, 2022
541
Hunter 380 Comox BC
We removed the OEM gauge and connected the tank sensors to the Cerbo GX analog inputs. The CerboGX is connected to the N2K network and sends the levels throughout the ship.
Like others have said, I'll keep my simple resistive floats for as long as they work... We did have to replace the holding tank sensor after 24 years. The other neat party trick with the Cerbo GX is you can calibrate the sensor resistance to the shape of the tank, making them quite accurate. Our fuel tank is within 1-2 L. Our fresh water tank runs out about 20 seconds after the Cerbo GX says it's at 0 L. You just need to figure out the shape, spit that into AI along with the resistive limits of the sender (full / empty) and it will spit out a correction chart. For the fuel tank, we tweaked it by refuelling.
For LPG we use a wireless bluetooth sensor, which also goes to the Cerbo GX.
Jun 17, 2022
541
Hunter 380 Comox BC
Serves me right .... my fresh water tank gauge just started to go a little wonky last weekend ... sigh..... if it's not one thing, it's another. :)
Sep 30, 2008
101
Hunter 37.5 37.5 Norfolk
I replaced all tank sensors on my boat with ones similar to the ones you find on Amazon for anywhere from $29 and up that is a straight tube with a float inside. They even make them for holding tanks with a protective tube that keeps the toilet paper and feces out of the sensor. I have never had a failure in 12 years. They do requires 12vdc for power. You only need to know the depth you want usually in inches. I chose one 2 inches less for my fuel tank so when the gauge reads "O" I know I have a few gallons of fuel left in case I need it for getting back to port.
Jan_H
Aug 17, 2009
41
2 26 Midland
I recently installed a Simarine STR1 tank sensor on my waste tank. Simple stick-on installation, and it has 0-5 V, 33-240 Ohm and 0-190 Ohm analog outputs, so replaces most analog tank sensors. A NMEA2000 is also available. It has an easy to use Bluetooth interface, and a nice feature is that it can be easily calibrated in the app for various tank profiles.
Interesting. Tank level technology seems to be moving towards these micro radar. The Simarine unit is considerably less expensive than the Gobius C which uses the same tech.
Ward H
Nov 7, 2011
3,836
@Jan_H At this price range I'm interested in the STR1 for the holding tank on my C30. Can you share where it shipped from? I couldn't figure that out from their website.
