Raymarine Autopilot Remote Control
Jun 21, 2004
3,137
Beneteau 343 Slidell, LA
Have any of you installed the Raymarine autopilot wireless remote control (RCU-1)? If so, is the convenience worth the cost and was the installation process relatively easy?
colemj
Jul 13, 2004
1,085
I can't answer those questions for the RCU-1 specifically. However, we have a wireless remote for our B&G AP.
We have never used it. Remotes sound like a good thing, but I haven't had any case where it was more convenient or useful than just using the AP control head itself. For those times where course corrections or direction changes are to be made, I always want to be at the helm near the plotter to ensure that the changes are appropriate, and to be ready to take over the wheel if something goes wrong. For those times where we are threading our way through a coral reef, I don't want to be controlling the boat from the bow with an AP remote, and one of us is bow watch then giving directions to the helm.
I can't think of a single use case for us where a remote control is useful or more convenient.
Perhaps single handers would have a different opinion, but I'm not sure mine would be different if I was single handing.
Mark
Edit: I just looked at the RCU-1. It has two features our B&G does not. The point and go function is just silly, so I discount that. However, it seems to have a solo sailor function that turns the boat into the wind if the person falls overboard. This might be useful for a solo sailor.
I would be concerned that it is triggered simply by loss of bluetooth connection, and that might mean some surprising unexpected boat movement if the remote batteries go dead or the remote signal is blocked by something. The latter can be more common than you expect, as bluetooth tends to be squirrely this way. We have several BT device on our boat where I lose connection to them when I am in certain areas of the boat. Not because I have moved outside of range, but because some combination of fixed things between me and the device are causing problems.
Also should note that while the AP might turn the boat into the wind, this will be a very temporary thing, as once boat speed is lost, then the AP has no control over it anymore. The boat could tack/jibe and take off in a different direction, the AP gains control again and turns it up again (if doing so repeatedly is part of its function), etc, etc, until one has no chance of getting back to the boat.
We have a B&G AP with the remote. There are times it has been very useful. In inclement weather we keep the remote in a pocket and use it to make minor alterations in our course. Our hands stay warmer this way. We seldom use it away from the helm for the same reasons Mark doesn't use it. Our course changes are minor and we want to see the chart when we make changes. It is seldom used when sailing in open water, with the sails up the AP is set to steer to the wind.
If we had a steering failure due to a broken cable or quadrant, the remote would make steering easier and less tiring than using the emergency tiller. We have no real life experience with this condition.
As far as installation, the B&G remote simply plugs into the N2K network and it is good to go.
colemj
Jul 13, 2004
1,085
Wouldn't the AP controller work for this too?
I guess we do have the remote in case we lose our controller (no other way to control the AP), so admittedly it is good for that.
I looked up the RCU-1 installation and it is the same as B&G - plug the receiver into the N2K network and good to go. As easy as it gets.
But $550 - definitely not worth that to us. Our remote was tossed in as a package deal for the entire system, which is the only reason we have one.
Mark
May 29, 2018
674
Canel 25 foot Shiogama, japan
RE: If so, is the convenience worth the cost and was the installation process relatively easy?
I have a Raymarine tillerpilot with a remote controller that came with the boat. I played with it 5 years ago and haven't used it since.
However I went to the Raymarine page and check the unit that you are interested in ($299 USD).
There was the usual blurb, "Intuitive Control" and "Built for the Marine environment".
However there are became aware of some interesting features.
Gary
We don't have a controller, we control the AP with either of the 2 chart plotters onboard or the remote which is just a fob, nothing fancy.
