I Don't think my temp light is working. I don't think the temp should light up when the key is turned (the battery and oil light do come on, and buzzer) but it should illuminate when the test switch is pushed up........does that sound correct?
Should I troubleshoot it by grounding out the wire at the temp sensor on the engine to make the light come on?.....looking at the diagram, that should make the light come on........correct?
Or perhaps I just need a new bulb.........looks like the 3/8" one......if someone could verify that for me.
Any other troubleshooting ideas?..............other than cleaning off the corrosion......
Thanks..............Tim
