I was taking my 1988 O’Day 322 out for a sail yesterday. Light winds, but I was hoping to make a go of it.
I got the boat ready, and even cast off the lines before I started the engine. Winds were so light, the boat barely moved in the slip…
I started the engine, and moved the shifter from Neutral to Reverse to back out of the slip...when BANG…something broke in the pedestal and the shift lever just dropped limp. All I can say is I’m glad the transmission didn’t engage in Reverse before the shifter broke. As it was, I could jump on the dock and tie the boat up so I could figure out what happened.
But I did think about it afterwards….what if the transmission would have engaged, and then the shifter broke? Would I have had the calm nerves to just back out to the fuel dock and tie up there? Or head for the open lake and cut the engine and drop the anchor? Or would I have panicked and hit the boat behind me? I will never know, I guess. But good food for thought.
After investigating and removing the compass from the pedestal, I found that the Edson “fork” linkage broke. The fork connects the transmission lever to the Morse cable. The Morse cable threads into the fork and in my case, the cable was only threaded in about 2-3 threads…and the tip of the fork linkage broke right off.
In this photo, you can see the fork, the broken tip and the lock nut that keeps the cable from backing out of the fork. I am assuming the cable was never threaded in correctly as the locknut was tight against the broken off threaded tip.
The good news is that:
1) I was able to thread the cable into the remaining threads on the fork linkage and it is was more engaged than it was…and I can use Tally Ho
2) I found a new fork on eBay for $15 and it is on its way…probably just become a spare for now, but it will be available if / when I need it.
Cheers,
Cheers,
on the dock and talking about knots with a Hunter 36 owner, one of our dock mates, a rather salty old fisherman, stops and asked if either of us sailing whenies knew how to tie a Dragon Bowline.
