What size handle for Whale pumps?
Sep 24, 2018
4,682
Catalina 30 MKIII Chicago
I have a Whale hand pump as a backup but the boat did not come with the handle. Does anyone know what size rod/tubing the handle is supposed to be? Looks to be around 1/2" but I can't get a measuring device deep enough to measure the hole in the metal
Mine came with the pump. I’ll let you know tomorrow morning.
Mine also is about 10-12 inches.
I think we have a different pump. The handle is part of the pump.
Sep 24, 2018
4,682
I'm looking for the OD of the end of the handle that goes into the pump. I can grab the model later today
Can you reach down far enough to paint the lip of the recieving hole for the handle? Maybe coat it with some shoe polish or other colored paste (mascara?). Then reach down and press a sheet of paper over the opening of the receptacle and make a negative. Bring that up and measure the diameter of the imprint.
4,682
No model number listed on the unit. There's at least an inch of rubber that is blocking me from getting an accurate measurement of the pump handle receptacle
Do you have scrap PVC in your shed? You could try running a short piece of pipe into the hole until you find a size that fits.
5,999
Oday 322 East Chicago, IN
I will probably get out to Tally Ho tomorrow and can get you a measurement.
Jan 7, 2011
5,999
Here are some photos to help you out Dave…
Looks like about 1/2”, but slightly bigger. I don’t have my calipers on the boat.
I am not sure what model I have, but took a photo of it too for reference.
Jan 7, 2011
5,999
I saw this on Amazon…
lists 19mm or .748 inches…. No guarantee it fits your pump, but I bet this is the diameter.
AB Tools Replacement Handle Manual Whale Gusher & Titan Bilge Pump Stainless Steel
Jan 7, 2011
5,999
Well, dang….now I found this one….and it is listed at 16mm… or .629”.
I bet this one fits my pump.
Sep 24, 2018
4,682
Thanks Greg! I'll order a 1/2" stainless rod. McMaster has them for around $10 for a one foot section. The second handle you posted is what I had on my O'Day. The pump has a male fitting that fits inside a 3/4-1" aluminum tube that makes up the body of the handle
Sep 26, 2008
792
Hunter 340 0 Wickford, RI
I was out on my boat today and remembered to get you some pictures of my Whale MK3 Gusher Pump. A different model than Gregs but may help you for a comparison.
