This is from a previous post
Aug 16, 2021
Before drilling for the easy out try beeswax and some heat. after a few cycles of heat and beeswax drill the whole and use the easy out. you will be amazed how this breaks up rust weld. I would only use the square type easy outs. I never had much luck with spiral type. read below for more info.
this is from acprevious post of mine
If you have stuck rusty screws try using beeswax and heat. I have used this successfully too many time to count!
A Mapp Gas torch will get it hot enough, maybe to hot. The trick is to use heat and beeswax. Beeswax can be bought at hardware and marine stores and has thousands of uses. Heat screws with a torch and then touch the beeswax to the screws. The trick is to heat the screws add some wax and then use heat add more wax. That way you don't have to overheat anything. The wax will penetrate much deaper than PB or any petroleum based penetrant. Look up using beeswax to remove rusty bolts on YouTube for more info. This works great on aluminum and stainless hardware.. I used this process on my c-22 mast to remove stuck screws and the Clevis pins in the mast head. It worked great no damage to the mast, masthead or the pins. Pins were original from 1974 and very stuck! A small hammer, beeswax and a mapp gas torch was all that was needed. Then use Marelube Tef-45 to keep them from corroding on reassembly. You can find Marelube at west marine or Catalina Direct. You don't use much so a small sysringe goes a long way.
The linkbelow has more detail on beesway
Who has bees wax in their tool box ?
Recently I retired from going to sea for 30 years. I sailed deep sea as an engineer. Every ship had blocks of bees wax in the machine shop. It is for sale in the Mariner's Catalog. Steam engineers, even before the Cival War, melted wax on hot stubborn nuts and bolts. It would seep into any...
www.garagejournal.com
Good luck, Dano
