Is this what you are looking for?Does anyone have outboard engine mount for a Typhoon in reasonable condition?
The picture I posted was from a Typhoon but... maybe a different model. I also found this pic.No. The Typhoon uses a deck mounted fitting that a bracket drops into so it can rotate down toward the water. The bracket also has a wooden block on the end for motor clamps .
Thanks anyway
