Hi Catalina owners. Anyone experienced water intrusion in the area just aft of the bilge that has exposed high density foam? From researching, it sounds like that is part of the internal grid structure, and I'm sure not supposed to be getting water in it. I'm getting water that I believe is salt water in that compartment and it drains into the bilge through the small irregular-shaped hole (above the PVC tube) in the aft section of the bilge. I can get my hand in there and feel the foam is soaked. I shop-vacd the water out and got a small chunk of foam that broke loose. I'm guessing it's the keel joint that is leaking? I don't see any of my through hulls obviously leaking on the inside of the boat, and the water does not seem to be coming up from the keel bolts themselves. One of the keel bolt washers is getting very rusty (next to float switch), so I'm a bit concerned about crevice corrosion. I'm sure I will need to pull the boat and deal with this, just wondering if anyone has experience with these particular symptoms. I'm hoping that I'm not looking at a full keel drop, but tough to know yet. Thanks for any contributions!
