Inflatable Boat Bench Seat
Aug 17, 2013
1,339
Pearson P30 202 Ottawa
Third picture, on the inside wall of the inflatable, there is a piping, deflate a bit the boat and insert the channel in the piping and re inflate
Aug 17, 2013
1,339
Ok, strange, I thought it was piping on the pic with the inflation hose, that is usually how the seat holds in place
dmax
Jul 29, 2018
1,347
Telstar 28 Buzzards Bay
Odd to have a handle on the inside, it has to be involved in holding the seat, it's in the right place.
shank
Apr 20, 2016
136
Catalina 27 5231 Lake Champlain
It looks like the seat slides on to piping or a rail like Fred said but I don't see anything there.
colemj
Jul 13, 2004
1,131
That seat doesn't go with that boat. The correct seat would have something like an L bracket on each end that hooks on the straps in your picture.
Mark
shank
Apr 20, 2016
136
I was thinking the same thing. I'll see if I can find brackets. Thanks for the help.
Jun 1, 2004
8,339
You might try making them out of wood. The you could round off all the edges and corners to reduce severe chafing or gouging.
Likes: shank
Mar 26, 2011
4,008
Corsair F-24 MK I Deale, MD
I think you have the wrong seat for that boat. I had that boat, and the bracket was different.
I'm sure they could be bent from aluminum. But it would require tools you probably don't have.
Likes: shank
colemj
Jul 13, 2004
1,131
The brackets you need look like this.
You could make them out of aluminum or fiberglass. Probably not wood.
Likes: shank
