I have a small but not insignificant leak coming in the top seam of the aft bulkhead of the aft cabin, just aft of the binnacle on my 1993 Hunter Legend 35.5. It only happens when water gets into the cockpit, from rain or washing down. It’s enough of a leak to soak my bedding and leave an inch in the bilge after a good rain (with the canvas removed, letting full rain hit the cockpit). I have confirmed all the cockpit lockers are draining properly and no water is entering at those points. It seems the only likely place is at the helm. Everything aft of the bulkhead is bone dry. Does it seem the likely source is at the binnacle? Am I potentially missing something? The entire ceiling of the aft cabin is one molded piece so I can’t really inspect the bottom surface of the cockput, but water is only entering at the trough under the binnacle.
there are four bolts at the binnacle and mounting plate that penetrate the cockpit sole. They appear pretty well sealed. The trough under the binnacle shows no cracks or any potential points of ingress (see 3rd picture).
In the picture of the cockpit side of the trough, the green tape indicates the position of the affected bulkhead.
